Jan 14, 2018 #1 ib1-2 Member Joined Nov 6, 2016 Messages 84 Reaction score 1 Points 8 Location Tamworth Can somebody point me in the direction of where the live rear light wire is. I want to connect a rear camera to it but not sure which is the correct wire. Thanks in advance.
Jan 14, 2018 #2 Littlebruv Member Joined Mar 14, 2017 Messages 247 Reaction score 22 Points 18 Location UK I can forward you a manual if need to
Jan 14, 2018 #3 ib1-2 Member Joined Nov 6, 2016 Messages 84 Reaction score 1 Points 8 Location Tamworth Thanks Littlebruv. I have the wiring diagram but it's not clear which colour wire is ignition live.
Jan 14, 2018 #4 R robin New member Joined Aug 16, 2016 Messages 102 Reaction score 2 Points 0 Location Stockton on Tees UK Probably White wire. Stick a pin in it and test it with electric screw diver. Switch on and off to see if it’s ignition live! Because you stuck a pin in it/ thro it. The hole should be small enough not to matter if worried put some tape on it.
