oil for andreani fork cartridges
D
Deleted member 1834
Hy lads. have got hold of some new andreani cartridges for MT 09. can any one give me any advice on fitting these to bike. Do you have to use ohlins oil as have been told that ohlins is only for track use. also read that you have to set up pins that are under the fork caps before you fit to bike. totally confused by that one. is there any standered settings that you start with when first fitted. would appreciate any help with this as a bit in the dark. Many thanks:
astradaryl
Suffolk
Did they come with instructions?
I would say you use standard fork oil unless it tells you to use something else in the instructions
D
Deleted member 1834
many thanks for imfo and instructions found them really helpful.,
