- Joined
- Jun 13, 2013
- Messages
- 275
- Reaction score
- 4
- Points
- 18
Complete 2014 Yamaha FZ-09 Technical Specifications:
ENGINE
CHASSIS
CRITICAL DATA
ENGINE
- ENGINE Liquid-cooled, DOHC, 12-valve, inline-three cylinder
- DISPLACEMENT 847cc
- BORE AND STROKE 78 x 59.1 mm
- COMPRESSION RATIO 11.5:1
- MAXIMUM TORQUE 8.9 kg-m (64.3 ft-lbs.) @ 8,500 rpm
- ENGINE MANAGEMENT YCC-T & D-Mode (3 positions)
- FUEL DELIVERY Mikuni 41mm throttle body F.I.
- LUBRICATION Wet sump
- IGNITION / STARTING TCI / Electric
- TRANSMISSION 6-speed
- FINAL DRIVE "O"-ring chain
CHASSIS
- SUSPENSION (FRONT) Adjustable 41mm inverted fork
- SUSPENSION (REAR) Adjustable link Monocross
- BRAKES (FRONT) Dual 310mm discs / radial mount 4-piston calipers
- BRAKES (REAR) 245mm disc / single piston caliper
- TIRES (FRONT) 120/70ZR17
- TIRES (REAR) 180/55ZR17
CRITICAL DATA
- LENGTH 2,075mm (81.7") WIDTH 815mm (32.1") HEIGHT 1,135mm (44.7")
- WHEELBASE 1,440mm (56.7")
- RAKE / TRAIL 25° / 103mm
- SEAT HEIGHT 815mm (32.1")
- FUEL CAPACITY 14 litres (3.1 imp. gallons)
- WET WEIGHT 188 kg (414 lb.)
- COLOUR(S)Vivid Red, Dark Metallic Grey
