24000 mile service
biggeorge
east yorks shire
Hi just had my MT09 TRACER a 24000 mile service and 5 valves needed to be re shimmed,so total cost was £565.00.
expensive , never paid as much for any of my cars !!:cool:
Stripy
Manchester UK
Ouch, that sounds a tad expensive - but be glad you haven't had a Trumpet - that would be your price nearly at every service :)
Where did you get it serviced?
seems flippin expensive! I thought shims would be no more than £5 each.
I'm sure my dealer quoted me approx £350 for the 24000 service (mines now at 20200 miles)
Is there a big difference between checking and swapping over?
I am surprised 5 valves needed adjustments,was the bike running fine and starting well?.
Chuck Thrillseeker
Australia
common problem by all accounts! Here on an Australian forum nearly everyone is having the shims done too and here in Oz it's a little over a $1000 for that 40k service
cheers chuck
chump
Bourne
cams out to change shims hence high labour cost.
your £350 will be to check clearances only, not change shims.
cheers chuck
Chuck are the people getting the valves adjusted reporting running and starting problems? Cos with 5 valves needed adjustments I would have thought there would be some running issues like bit of noise or poor starting.
Chuck Thrillseeker
Australia
No most are just as surprised as you are hearing about it. They never new anything was wrong! yet all had tight valve clearances?
A couple of people have had their 40K service and not had any problem but there does seem to be more that need it. Another note was they were all the early models, people are wondering if it has been addressed with the later models
cheers chuck
Let's hope so chuck, mines due its 6000 mile service next month I will ask if they have had many valves to adjust and report back,I let dealer do my first service for my warranty then I will do the 12.000 miles service and so on so I could do with out having to adjust valves.
Kimmie
Sydney, Australia
cheers chuck
Just did the 40K service on mine (hubby did the valve clearances) and it needed 2 shims replacing, everything else was ok...just need to tighten the new chain a little.
$1000 for the service is a standard cost for this service...I nearly fell over...WOW.
Lucky I have a good mechanic (hubby) that charges mates rates.... :D
Had mine done yesterday, it has done 25200 miles. Cost was £400, 3 shims were replaced.Apparently took 6 hours. Didnt need plugs or air filter, as were done last time
kev
Selby
As my dealer can't even top the oil up, I will not be getting it serviced by them, as I have no intension of selling my bike, I'll service it myself, the money I "hope" I'll save will go towards a new bike, although if it lasts as long as my FZ6n did it might be a mobility scooter I'll be buying?
