Auxiliary connector location
woodie100
Hi John,
Good to hear from you again. I can’t find the Aux plug on the right side at all so as a temporary (as in I fully intend to re wire it once I find a switched live supply) I’ve wired it to work regardless whether the ignition is on or not. So you imagine just how chuffed I was to discover this Aux plug! I have now got the correct plug ready to re wire the DLR but can’t find the plug on the bike anywhere! Would it be tucked behind or folded up under the tank? Or maybe as I have heated grips, it’s being used already? The 1st picture I took had 3 connections is that standard or has the Aux connection already been used? i.e. is it standard to have 3 plug in connections like the first picture I uploaded ?
Sorry to be a pain but I know 100% it’s only a matter of time before I leave them on by mistake and then have a flat battery!!
JonB
JohnD
I have the tracer and the plugs are under the dash. Two grey 2 amp and two square ones. Factory heated grips use one of these plugs, dont know which one though.
woodie100
O ok so how do I access these plugs? Do I have to remove the screen? Surely I don’t have to lift the lcd display?
JonB
Otters Pocket
Remove screen, then remove the plate the screen screws to, then there's a cover that is removed with some plastic lugs that you push the centres to release. The plugs are easily accessible underneath that.
This is on the Tracer though, not sure if the MT is slightly different but wouldn't have thought by much,
woodie100
Hi Otters pocket!
I actually do have a Tracer on a 16 plate. I also have the larger Givi touring screen (On there when I bought the bike)
I will have a look when I’m off next (work shifts)
Thanks for the info tho!
JonB
woodie100
JohnD,
That's perfect thanks!! I actually managed to rewire the DRL yesterday (only just seen your post this morning!!) but all went well and the lights now go off with the ignition. Think I'm pretty much done with mods now so happy happy happy!!
Thanks again for you're input and guidance/help, very much appreciated.
JonB
woodie100
I only found 2 round and one square plugs free so guessing the grips are using the other square plug although I didn't see it!
JonB
