drive chain dust?
Unfazed
Medway
Wondered why the chain whined when adjusted to the book figure! Backed it off and it has been fine.
Tensioned it correctly with wheel aligned right as well
bullock
nottingham
Yes definitely lubed and applied quite a bit to it using WURTH HIGH PERFORMANCE DRY CHAIN LUBE. I am also using a tool to make sure the chain is aligned & tightened according to the manual.
According to the manual, the chain needs to be adjusted to 5/15mm slack whilst on the central stand - which seems to be quite tight.
Too tight 30mm total up and down when on centre stand also I use wd 40 chain oil lube done 16000mls no prob with anything,
Hope this helps
