Dumb or not so dumb wiring question.....maybe??
Likes
Hi all
I have bought a pair of air horns to replace the rather wet stock horn. The problem that I have is that I have seen on YouTube that the positive from the battery goes via the switch to terminal 86 on the relay. I have sound which wire that connected to the stock horn, when the button is pressed becomes live. Not problem I thought, connected up inc compressor for horns, but where oh where does the other wire from the horn go? A simple ohms check shows it a neg/ground connection so I thought simple, connect that to pin 85 but it don't work!! few fuses later on, I'm stumped!!
The guy on the video stated that he made a mistake by the switch (should not have the thin line there).....what am I doing wrong?? I have tested the compressor and that works fine so im stumped!
JonB
Likes
Cheers John, I'll keep that in the pocket for if/when I get a set of spots for the bike!
I think that I have cracked it (or my father in laws son has if im being honest!) and will try it tomorrow.
Thanks again for the help you have given me (y)
