sticky out number plate thing!
floyd
manchester uk
hello all, im picking up my mt09 tracer thursday this week, can you remove the long bracket inbetween the plate holder and bolt the existing mount under the seat? or do i need a tail tidy? thanks in advance :)
Tanky
Kent
All I've seen is a shorter stem that your original Number plate bolts onto making it shorter.
I have a R&G tail tidy and looks the nuts.
Hope it helps
T
offo
Ipswich, Suffolk
I think it's a case of buying a tail tidy, just bear in mind that if you are going to fit panniers for touring then you also need after market indicators as panniers wont fit with standard indies on a tail tidy.
floyd
manchester uk
cheers i had a quick look in the shop, the reason i asked is the hole centres at each end of the long bracket looked the same, probably will have panniers on at some point will have to put back to standard for the trip.
