I have the same problem...Got and installed it, but it doesnt deliver enough power to charge my phone, losing power when plugged in and have GPS running.
Is that normal or did I install it wrong?
What your battery status reads when you plug in phone to bike socket? Charging USB or AC? Bc if your charger acts as USB data port phone will draw only 500mA which is not enough for gsm/gps stack , display and and probably BT and other stuff you have running.I have the same problem...
Galaxy S2 running a GPS applications, loses power rather than gaining it [emoji20] .
If the phone is idle it does charge up, but ever so slowly.
Thought it was only my problem...
Only thing I can suggest is try some power saving settings and lock the screen maybe if you're on a long stretch of road for a bit without the need for navigation.oh well...waste of money ...
Thanks everyone
They come with dedicated chargers which with more current, plus sat nav mostly has only gps chip(sometimes a-GPS).Only thing I can suggest is try some power saving settings and lock the screen maybe if you're on a long stretch of road for a bit without the need for navigation.
On a side note, I wonder how dedicated motorcycle sat navs perform when plugged in to the bike?
Mines showing AC charging, I already checked that.What your battery status reads when you plug in phone to bike socket? Charging USB or AC? Bc if your charger acts as USB data port phone will draw only 500mA which is not enough for gsm/gps stack , display and and probably BT and other stuff you have running.
