- Joined
- Jun 13, 2013
- Messages
- 275
- Reaction score
- 4
- Points
- 18
Introducing the all-new 2014 FZ-09, a naked sports roadster powered by an all-new liquid-cooled, 850 cc in-line 3-cylinder, fuel-injected engine. The FZ-09 has been developed around the concept of a "Synchronized Performance", that allows a rider to enjoy the feeling of complete control in typical everyday riding situations. In other words, the FZ-09 has been designed to respond to your every command.
/// Power
Slim, compact, 847cc, DOHC, 12 valves (4-valves/cyl), liquid-cooled, 42.5 degree inclined, inline-three cylinder engine. The engine has been tuned to provide plenty of low to mid-range torque with strong yet linear throttle response.
/// Engine
/// Chassis
/// Critical Data
/// Power
/// Engine
Engine |
Liquid-cooled, DOHC, 12-valve, inline-three cylinder |
Displacement |
847cc |
Bore and Stroke |
78 x 59.1 mm |
Compression Ratio |
11.5:1 |
Maximum Torque |
8.9 kg-m (64.3 ft-lbs.) @ 8,500 rpm |
Engine Management |
YCC-T & D-Mode (3 positions) |
Fuel Delivery |
Mikuni 41mm throttle body F.I. |
Lubrication |
Wet sump |
Ignition / Starting |
TCI / Electric |
Transmission |
6-speed |
Final Drive |
"O"-ring chain |
/// Chassis
Suspension (Front) |
Adjustable 41mm inverted fork |
Suspension (Rear) |
Adjustable link Monocross |
Brakes (Front) |
Dual 310mm discs / radial mount 4-piston calipers |
Brakes (Rear) |
245mm disc / single piston caliper |
Tires (Front) |
120/70ZR17 |
Tires (Rear) |
180/55ZR17 |
/// Critical Data
Length |
2,075mm (81.7") |
Width |
815mm (32.1") |
Height |
1,135mm (44.7") |
Wheelbase |
1,440mm (56.7") |
Rake / Trail |
25° / 103mm |
Seat Height |
815mm (32.1") |
Fuel Capacity |
14 litres (3.1 imp. gallons) |
Wet Weight |
188 kg (414 lb.) |
Colour(s) |
Vivid Red Dark Metallic Grey |
