T
tango
Yamaha FZ-09 847cc $7990
Triumph Street Triple 675cc $9399
MV Agusta Brutale 800 798cc $13,998
2014 Yamaha FZ-09 Specs
MSRP $7990
Engine Capacity 847cc
Engine Type Liquid-cooled, DOHC, 4-stroke, 12 valves
Bore x Stroke 78.0 x 59.1mm
Compression 11.5:1
Fuel System Fuel injection
Transmission 6-speed
Clutch Multiplate wet clutch
Final Drive O-ring chain
Frame Aluminum frame with externally mounted swingarm
Front Suspension 41mm fork; adjustable preload and rebound damping, 5.4-in travel
Rear Suspension Single shock; adjustable preload and rebound damping; 5.1-in travel
Front Brakes Dual hydraulic disc, 298mm
Rear Brakes Single hydraulic disc, 245mm
Front Tire 120/70-ZR17
Rear Tire 18055-ZR17
Seat Height 32.1 in
Wheelbase 56.7 in
Curb Weight 414 lb
Fuel Capacity 3.7 gal
Electronics Ride-by-Wire, Yamaha Chip Controlled Throttle, D-Modes
Colors Rapid Red, Liquid Graphite
MSRP $7990
Compression 11.5:1
Seat Height 32.1 in
Wheelbase 56.7 in
Curb Weight 414 lb
