Hi there, just back from a "spirited" 4 days in the Germany/Luxembourg area and I found a rather hideous problem when I was down changing using engine braking into hairpins, especially on the downhill sections when the back wheel locked up momentarily when going into 1st. At lower revs, not a problem but when in the higher rev range having trouble. Sometimes it refused to go into 1st at all leaving me free wheeling and grabbing a load of brake! This is the first time I have given the bike some real welly as the mileage before was all commuting and don't get too many mountain passes on the A2
I've always had 4 cylinder bikes and this was not an issue, never had a twin and when I was dirt bike riding on a single the engine would lock up if down changing too rapidly. Is this a triple issue? Even tried gently letting the clutch out and it still locked up. I know the bike doesn't have a slipper clutch or anything that fancy. Sometimes it got stuck in neutral and was reluctant to even shift back up to 2nd.
These are not the experiments you want to try hurtling into a wet mountain hairpin at speed! (BTW the plastic Dunlop stock tyres are shite. After the long weekend I REALLY know it from experience!)
I've ridden numerous sports bikes (4cyl) and not had this problem before, I'm down changing between 5 and 6K revs on the Tracer,
Also, as I was shitting bricks and putting on some brakes to help, the back break pedal seemed to lift up for a pulse.
Just putting this out there, see if anyone else had a similar problem with engine braking.
BTW the bike is an animal in mode A. First time I tried it, it felt like a different bike, very exciting! Seemed to have sorted out the suspension by having 1 ring showing on the front and second hardest setting on the back. Might even put full pre-load (no rings showing) on the front to try it out. Damping is 4 clicks from fully soft on the front and 1 1/2 turns on the back. Might try 1 3/4 turns from soft as I could still feel a bit of bounce on fast undulations
Very good trip in the Ardenne/Eiffel region and will be going again this year with better rubber
