l34chy
- Joined
- Jul 27, 2014
- Messages
- 182
- Reaction score
- 0
- Points
- 0
Just one question.
Why?
I find the stock brakes are excellent but the forks are so soft you can't use them to the full. Fix your forks first and then try your brakes for size.
Already on with that and at 130mph I will stop atleast 50feet shorter than your stock brakes with less effort and more feel
Same here. I went with a biger master (16mm - FZ8) and 320mm EBC rotors & Pro pads. More braking power & better feel. Front suspension set-up is also very important.
What problems?Yes I was looking at the 320mm ebc rotors that will be on the shopping list once I have sorted the handling problems which will be very soon
What problems?
I'm 175 lbs w/o gear...
.90 kg/mm spring
GP piston kit with 7W oil
Oil level: 130mm
That fixed the front end for me...
Rear I use the ZX10 shock
27cc = 20mm oil level...I too have the GP Suspension kit. Holy wow, what a difference. I just raised the oil level to 130mm today, based on your setting. I'll see how it affects brake dive next time I get a chance to ride.
There is no need to spend any more on the front than this.
well I have the zx10 shock fitted but gonna be entering a few events next year so gonna treat myself to Maxton front and rear
The hole on the C clamp need to be drill from 10mm to 12mm (swingarm side)How easy was the ZX to fit mate? Any modding needed or can it just slot in
Then there's very minimal trimming of the plastic on the under tray for the canister to clear.
Cool. Thanks for that
If you want TT you can buy mine once I got the maxton in
Lets talk cash then???
