I have fixed my cam chain. Its easy, but will probably void warrenty but I'm tired of waiting for the shop.Ok. I'm still waiting on a backorder tensioner. So I fixed the problem myself. You need an inch long bolt same pitch as the middle cam one you take out and a couple of nuts to lock it home. So I had taken out the middle bolt, applied an allen key to tighten the adjusting screw (hand tight only). Then back the screw out 1/4 turn. The new bolt then goes where the old short bolt was and is locked down. Hand tight. The problem with the original bolt is the screw starts to back itself out after a while.I have posted this elsewhere first, but thought more people might benefit from a new thread.
