I did mine at about 1200miles. Just needed a couple of turns an it was spot on again... been perfect since and I've just done 6100miles.Anyone adjusted their clutch cable before 1k service?
I had trouble finding N after 300km, I turned it 1/4 of a turn and it was ok.I did mine at about 1200miles. Just needed a couple of turns an it was spot on again... been perfect since and I've just done 6100miles.
I find it more precise to adjust it at the clutch casing end rather than the lever end...I had trouble finding N after 300km, I turned it 1/4 of a turn and it was ok.
I would wind it in a tad at the lever end beforehand though before you start on the clutch casing endhow do i adjust this at the engine end? There are two nuts there on a cast bracket. The upper nut is impossible to get to? At the handle bar end I am at the maximum so no more winds possible
