so do any of you guys use the torque settings as stated in the manual or do you just do it nice and tight as in old school .
Defo torque setting as the rear spindle is not that good. Nice and tight mite result in snapping it. Obviously that's just my opinion.so do any of you guys use the torque settings as stated in the manual or do you just do it nice and tight as in old school .
yeah will follow the book then.Defo torque setting as the rear spindle is not that good. Nice and tight mite result in snapping it. Obviously that's just my opinion.
We nipped mine up at 1200 miles. Needed it as well lolyeah will follow the book then.
Mine has stretched some. I'll need to clean and adjust it soon, the thing is mingin'.has anyones chain stretched much ?
yeah its for tourqing the axle nut mate.I have no torque wrench yet. Maybe should invest in one but hadn't thought about it just for the chain adjustment. I always just worked on having the right amount of movement in the chain before.
funny enough we were talking about the chain tension the other day and both "my mechanic" and myself think 5-15mm is far too tight so we settled for 20-30mm as that's usually the rule of thumb..I took my bike to my dealer today and thought my chain needed adjustment anyway he said its fine and I trust him but he said the 5mm slack guideline in the manual seemed way to tight, so he phoned Yamaha uk and they also said that seems to tight so they said also said to not tighten to 5mm, its all very odd lol, do any of you know anything of this ? triple maybe your mechanic can help out here ?
I went through the aligning countershaft,swingarm pivot and rear axle procedure and set the chain slack at that position to 5mm.funny enough we were talking about the chain tension the other day and both "my mechanic" and myself think 5-15mm is far too tight so we settled for 20-30mm as that's usually the rule of thumb..
no problems so far..!
crescents in Bournemouth, let me know when you move mate we can meet up.Which dealer do you use Fly? We are moving to Poole this summer.....
