Hi,
I'm sick of my bike getting wet and dirty in the winter and cooked in the desert sun in the summer, while parked in my outdoor parking space. So I've decided it's time to put up some lightweight roofing over the parking space.
I'm going with a lightweight polycarbonate material, called Suntuf, which is produced and sold locally.
My parking space already has three walls, so all I'll be needing is to put steel rectangle tubes from side to side, on which the roofing will rest.
I've never worked with steel before, and I really don't know what size I should be using for this job. A 6 meter span, is pretty long. I want to choose the correct profile, so that on one hand it's strong enough to support it's own weight without sagging (the lightweight of the Suntuf is negligible), but on the other hand not over massive/heavy.
Do you have any experience with construction from metal?
What size would you recommend?
I'm currently considering the more massive 10cm x 5cm profile, or the smaller 6cm x 4cm (both aprox. 2mm thickness). But I'm really just guessing here....
Any help is much appreciated.
