Ignition Switched Live Wire Location ?
crotchrocket
Hi Guys,
Has anyone come across an ignition switched live i can tap into? I am fitting a kliktronic gear shift to the bike tomorrow, and need an ignition switch so the unit turns on/off with the ignition. There is no real load on it, the unit connects to the battery so its just a switch line. I could use a side light feed? Any pointers to wire colour and location would be great. Ideally under the seat somewhere :D
Stripy
Manchester UK
There is one, the aux output (secured by a 2 amp fuse) under RH fake air intake. It is mentioned in the manual as well.
