How did you tweak TPS sensor?
Throttle mod/ECU - Page 2
Read further on down the page to see info on using the bikes DIAG menu to help you set the sensor.
Seems like this map will digitally slow initial throttle response and also remove the hesitation caused by the very lean mixture...
Well as we now know the remap doesn't alter the mixture, so weak fueling is still causing hesitation on fixed throttle because our UK E5 pump fuel needs a stoichiometric AFR richer than the 14.7:1 the MT09 receives during closed loop fueling. E10 actually requires 14.08:1 so it could get worse if/when that gets dispensed at the pumps.
Anyway I came across the Yamaha MT-09 FZ-09 MT09 FZ09 O2 Controller Fuel Mod on €bay as a cheap way to solve this exact problem which I have on my bike.
I found Tha the Yamaha remap cured this pretty much.
flipper whats your nitron shock like ?
If you guys need any info on the O2 controller let me know.
yes please kev
Would this be the Kev of kevmod fame on the XT forum? I did the Kev mod on my sons XT and it worked awesome!
I think I'm sold on Kevs controller, just need to get the yam ecu update done first.
That's not happening until I can stand in the garage without shivering though
Perhaps I should pop over to Brisbane for free fitting :lol
