After seeing what the original pieces are made from, I won't be spending money on replacements ! What it really could do with is some actual Ram-air tubing running past all the wiring hidden beneath the ducts and feeding the air intake. That big hole in the airbox lid is the inlet snorkel. It must be an asthmatic bike right now.I took my air intakes off to fit my Evotech mesh grilles and I accidentally pushed the middle all the way through on one of the clips and lost it for about 40 minutes.
Searched the garage floor for ages until it finally fell from the bike where it had been stuck all the time I had been searching.
Felt a right numpty.
Just noticed the position of your injector nib in the pics, you might want to check this out...... Scottoiler | Motorcycle chain oiler | Scottoiler FS 365
As I don't have the bike to mooch around yet... Where is the ABS void? Any chance of a pic? I've googled for it with no success. If you were to mount the reservoir in the void how easy would it be to get to, to refill? Is access good and does bodywork have to come off to get to it?Fitting the Scottoiler
Mounting the reservoir body is the easy part, you have two choices, ABS void is a good one (if you dont have ABS) or the easiest is the frame rail....
Is this the ABS void?As I don't have the bike to mooch around yet... Where is the ABS void? Any chance of a pic? I've googled for it with no success. If you were to mount the reservoir in the void how easy would it be to get to, to refill? Is access good and does bodywork have to come off to get to it?
Sorry to be clueless, I really have absolutely no idea where it is.
