Hi replaced mine with ohlins the bike has only done 1000 miles with origionals how much you offering
What's with everyone looking for R/H cartridges?
Sent from my iPhone
Its the one that does all the work standard, so if you have two right side cartridges installed both forks do damping not just one, the theory is it will double the amount of compression damping and you can dial the rebound back if necessary via the adjusters, cheap upgrade, I scored a set of standard cartridges from an Adreanni upgrade, will get some 0.95 springs, 5-7.5w weight fork oil (the 10w oil in it does a very good job at the moment, so with two working cartridges you will need to go with slightly thinner oil), Id suspect this will be a popular mod, but I suspect much like ZX10R shocks these will start disappearing fairly quickly.
