Rear axle nut size?
stunva
Country NSW, Australia
I want to know who's idea it was to have that floating bush thing in the middle of the rear wheat, what a pain in the arse.
relz
Israel
+1
I fixed a puncture last week. Wheel removal was a breeze, 10 minutes tops, but reassembly was a RPITA!
I was sweating over that thing for almost an hour....
Have to hold the wheel raised off the ground with one hand, and insert the axle, while jiggling it and keeping all the parts aligned, with the other.
I think I need to prepare me a tapered pseudo axle to insert from the opposite end, to get it all aligned before inserting the real axle.
Kinjane
Land of Enger
I place some wood under the front wheel, enough just to get the rear sitting down on the ground.
The axle then easily slides in and out and I can just roll the wheel out without any fuss or struggle.
stunva
I ended up using a T bar socket from the RH side to line it up as best I could and a rubber mallet on the other end done the rest......between knocking off the caliper bracket, knocking one of the bushes out, realigning the bush thing.
Took less time to put the new rubber on by hand than it did to put the wheel back on.
relz
Israel
I did the same, but the socket wrench handle that I used is narrower than the axle, so the bushings could still move around a bit.
If I can be bothered, I think I'll make a wooden dowel which is the same circumference as the axle, only with a tapered edge. Then if I insert that from the right hand side, it should push all the bushings into place and hold them there, while I'm pushing the axle in from the left hand side.
