What size is it M?
+1I want to know who's idea it was to have that floating bush thing in the middle of the rear wheat, what a pain in the arse.
I did the same, but the socket wrench handle that I used is narrower than the axle, so the bushings could still move around a bit.I ended up using a T bar socket from the RH side to line it up as best I could and a rubber mallet on the other end done the rest......between knocking off the caliper bracket, knocking one of the bushes out, realigning the bush thing.
Took less time to put the new rubber on by hand than it did to put the wheel back on.
