Accessory cables?
Jetty
Hi. Does anyone know if there are any ACC cables hanging around the dash, IGN or Permanent Live? ...May whack SatNav on...Could quite easily run wires directly to the battery(fuse inc.), but am curious...
Thanks
Jetty
Hope you get notification to read this RipGroove. Only just getting around to fitting. Is this connection a permanent live, or with ignition?
Thanks. :)
Thanks. :)
It's switched off of the ignition so it's all good. It's only live when the ignition is on.
Jetty
Thank you for that. Saves me poking around. Ideally I want a permanent live so that I don't have to re-boot my raging Zumo 550 satnav each time I fill up with juice. (I always forget to press the appropriate button to leave it running from its battery!).
welchyd1
United Kingdom
Hi, I am currently wiring up my SAT nav to this auxiliary plug. Is it fused or should I resolder the inline fuse to the love wire on the garmin harness and pop it in the "air vent"
