Yeah ok there is a connection but its not a black and white connection. That fuel only pops if the air is added to it. Reducing the engine breaking is done by adding fuel on decel, but no matter how much fuel you add it'll only pop if air is added.well they are connected as the popping is unburnt fuel being ignited in the exhaust while helped by the PAIR valve. it only starts popping below 4000rpm when the injectors are switched back on to stop the bike from stalling.
if you leave the injectors switched on all the way down to idle there will be more unburnt fuel going out the pipe which should equal bigger n better banging! yeaaaaaaaa!
