Bent selecter shaft
Andy Harrison
Anyone else think this is bent down maybe the cause of my gear change problems
Steely
Norfolk
Yes, that is bent, and is undoubtedly the cause of the gear selection problems described in your other thread.
Land of Enger
If you're going to replace that £70 part you'll need to grind off that exposed section first - it ain't being pulled through otherwise and applying any force in an attempt to straighten it could end up fracturing the casing.
Andy Harrison
Yes I got a top bike mechanic on the job he's told me the same thanks
