I've recently purchased some OEM Yammy heated grips for my Tracer. Fitment is excellent, however I noticed whilst riding on anything above the minimum heat setting the right grip becomes unbearably hot to the point it starts to burn my hand. Meanwhile the left grip only ever gets luke warm and any setting. Worth noting you really start to notice the intense heat when you get moving I guess because the alternator is pumping out more electrical juice - its felt dangerous at one point because I couldn't hold the throttle.
I had a look around on google at is seems on other forums some folks have experienced the same where others have not - maybe I have faulty grips?
Out of curiosity I swapped the electric plug connectors which interface with the bikes wiring between grips and this made no difference, right grip still burns my hand (I was testing this where air temp was aroudn 14 degrees).
I suspect it has a lot to do with the left grip being mounted directly onto the metal bar but the manufacturer should compensate for such by insulating more or adding something extra so the left grip can apply more heat.
My previous Honda never had this issue, in fact it was perfect temps on both sides.
To that end I've returned to the dealer as I can't see the point in them if one had only gets warm but at this stage refuse to give a refund as they say its an electrical item. Its back to Yamaha to see what they say......
