I have not heard from Reece for a while now, does he still have his 990SMR, I did a bit of work on it for him.G'day Kev,
I have a quick question on how this thing works. Not asking for trade secrets but before I attach something to my bike to trick the computer I like to know how it works.
Is it a static adjustment to the output of the O2 or is it a dynamic one which adjusts the offset based on the sensor output?
Reece, of KTM 990 SMR fame said to say hello by the way. He basically told me that if you're selling something to improve the 09 I must buy it lol
To answer your question the O2 controller adjusts the offset based of the sensor output constantly, the OEM O2 sensor generates it own voltage signal from the unburnt oxygen, this voltage signal is a square wave voltage signal, the voltage signal runs between Zero & 1 volt, my controller mimics the real live square wave signal from the O2 sensor & sends a new leaner voltage square wave signal to the ECU, the ECU recognises this corrected input signal from the controller which is offset slightly leaner than the actual A/F ratio in the pipe & in turn the ECU richens up the closed loop A/F ratio, the ECU rechecks the closed loop A/F ratio every time the motor fires & is constantly changing the closed loop A/F ratio to it's input trim table target values of 14.7:1 this is where my controller tricks the ECU into thinking the A/F ratio in the pipe is 14.7:1 but in real life the exhaust A/F ratio is approx. 13.6:1.
The ECU samples the A/F ratio every time a piston fires so the OEM sensor is constantly sending a different voltage signal in a square wave form to the O2 controller & the controller is adjusting to offset constantly trying to keep the A/F ratio to approx. 13.6:1 in the pipe. To see & measure the OEM O2 sensor input voltage to the O2 controller & to see & measure the out put to the ECU from the O2 controller I used an oscilloscope, channel A on the O2 sensor signal wire & channel B out of the controller signal wire, refer to link to see the actual A/F ratio signal changes, it the closed loop A/F ratio was static the A/F ratio signal in the closed loop would be a straight line. http://mt09.motorcycle-talk.com/for...evs-anti-throttle-surge-mod-25.html#post28943
