Hi Gang,
I recently purchased an LED relay to replace the OEM item on my MT-09 as I intend to replace all my bulb indicators with LEDs.
However, when I came to fit it yesterday I discovered that all 4 bulb indicators arrive at the OEM relay by just 2 wires (which are blue and brown) and plug onto 2 connectors on the relay (labelled L and B) but my replacement relay has 3 connections labelled L 5 49a, 1 - 31 and 2 + 49.
Those last 2 connectors I take the labeling to mean 1 negative 31 and 2 positive 49 ?
So, for the more electrically savvy amongst you, is it possible to use this new 3 connector relay to replace my OEM 2 connector relay and if so how should I wire it, or have I purchased the wrong part?
Taverymuchlike.
Taverymuchlike.
