Shad Cases
Hexme
Hampshire
Anybody have these fitted? £365 on Amazon for the full kit including hard cases and inner bags, nice
pavc
Just fitted some, sods law they were not that cheap when I ordered mine. They are a good strong case, when you come to fit the brackets on it's easier if you loosen the foot peg hangers as well, though these on mine were loctited on.
Hexme
Hampshire
Thanks PAVC, any chance of a couple of cheeky photographs?
pavc
Will put some up in a while for you.
pavc
Top box is a Kappa / Give 48N, panniers are the Shad 36, the white marks on the side rail is polish as they panniers where a tight fit. The panniers came with a spare lock which I assume is so that you can change a shad top box to use the same key as the panniers.
Mr. Funtcase
West Sussex
What's the width of the arse end with those fitted?
Looks wide but i expect it's the wide angle of the pic.
Be interesting to compare as my box panniers are 970mm.
Hexme
Hampshire
pavc
A very rough measure around 980 mm give or take a bit.
Mr. Funtcase
West Sussex
[MENTION=2381]pavc[/MENTION]
Would say mind you don't scrape them on the ground but looking at those massive chicken strips you got, no danger of that. :p
