It teaches you clutch control.
With my previous bikes, I've only used the clutch for gear shifting. Cornering consisted of entering at the correct speed and gear, and then control the turn and lean using smooth throttle inputs.
With the MT's jumpy on/off throttle behavior, I found this impossible, and it forced me to use the clutch much more in order to smooth out the throttle inputs while turning. Actually I realized that now I've got my fingers applying slight pressure on the clutch (probably not too good for clutch wear) every time I close/open my throttle, regardless if it's in a turn or on a straight road.
Hopefully, with the revised CO settings I can go back to the good old throttle only control when cornering, without needing to worry about clutching it, but I think the habit of clutching in order to smooth out throttle power is a good technique to master.
e.g. When riding in slippery conditions (early morning tires, or wet road), I think that keeping some pressure on the clutch can help keeping the tire from skidding/slipping due to throttle changes which deliver too much power than the tire can cope with under the conditions.
Just my two cents (or pennies)...
