marthy
Bike is super light. Too much pressure don't allowed the carcass to heat up enough. Front psi should raise about 3 psi and rear 6 psi. If you did a bit of chemistry you know the volume doesn't change, you can measure the pressure... +3F/+6R is about what you need to get the proper temps. Too much psi make the tire patch smaller too... less rubber on the ground.
My hot psi run F33/R35-6. I can ride the speed limiter all day long...
