Tracer kid
Do I take it the closed loop part of the map can't be mapped hence still needing the 02 mod doing ?
Nope. You won't need the O2 optimiser at all and yes it can be mapped.Do I take it the closed loop part of the map can't be mapped hence still needing the 02 mod doing ?
What reason did you fit the o2 controller on this (confused) ?I got the flash a few weeks ago. Simon fitted a K&N filter and 02 controller as well for me. The bike is a lot better now. I don't have to worry about the throttle in corners anymore and wheelies don't come crashing down. Got a bit more power as well. Well worth the money.
Thanks Simon and triple trouble. I will be back soon for the quickshifter[emoji4]
Sent from my XT1072 using Tapatalk
I read on the fz09.org forum that it does make a difference even with a flashed ecu. The guy who makes them explains how it works. I haven't tried without it though.What reason did you fit the o2 controller on this (confused) ?
But you had the controller fitted along with a K&N when we flashed your ecu. That's why we didn't disable the closed loop for youI read on the fz09.org forum that it does make a difference even with a flashed ecu. The guy who makes them explains how it works. I haven't tried without it though.
Nope. Simon fitted it when I got the flash.But you already had the controller fitted before we flashed your ecu. That's why we didn't disable the closed loop for you
I just said thatNope. Simon fitted it when I got the flash.
I think I get the picture.I just said that
I read that flashes only smooth things out above 6000rpm? True or false? Hence, it was suggested you get the O2 for below 6k and the flash for all the other features. If you only need the flash, i.e. it smoothes out the jerkiness of the throttle at low revs too, then why are people buying both? Wish I could get a few of you in a pub together and have a good debate on the pros and cons; I can see from the various forums and FB pages that I'm not the only one who is having trouble pinning down the best option. Thanks.Nope. You won't need the O2 optimiser at all and yes it can be mapped.
False. If you disable the closed loop it won't be "jerky" hence not needing the controller regardless of what rev the bike is doing.I read that flashes only smooth things out above 6000rpm? True or false? Hence, it was suggested you get the O2 for below 6k and the flash for all the other features. If you only need the flash, i.e. it smoothes out the jerkiness of the throttle at low revs too, then why are people buying both? Wish I could get a few of you in a pub together and have a good debate on the pros and cons; I can see from the various forums and FB pages that I'm not the only one who is having trouble pinning down the best option. Thanks.
Will that flash straight onto the mt 10 ecu then Rich?PCV fitted to the R1M and ready to be flashed, then have a custom map written for it...
Watch this space for the results peeps...[emoji106]
Don't think it will Keith...Will that flash straight onto the mt 10 ecu then Rich?
Already have a guinea pig for the MT10 though lol
Lol now there's a shockI think DC will be getting one, on his usual terms,,,,for nothing lol
At least I get a blast on it,,, can't be to harsh on him sold my enduro bike and he's going to get me a deal on a new oneLol now there's a shock
