Yamohlin
My bike (Tracer 24 months old 8k)is hooked up to an Optimate when not in use although I use it every week unless on holiday.
Back in November I went to start the bike but the battery was completely flat, I thought maybe I hadn’t connected the Optimate in the right order and it had drain the battery so I charged it overnight and it was showing fully charged in the morning reading 12.9 on the meter. I reconnected it and then rechecked it the next day and it was reading 12.8 which I expected as it has a tracker fitted to it, the meter read 14.2v when the engine was running at 2k. the bike was OK for the next couple of weeks but I was a bit dubious about leaving the battery as it was as it was 18 months old and having been completely discharged for I don’t know how long and as I do long trips mainly on back roads I thought I would change it for a Motobatt as it had connections both sides so I could easily connect the tracker, jacket & GPS to it.
I fitted the battery and since then all has been OK until yesterday as when I started it seemed a bit weak to start but did so I carried on to the pub (21miles) When I came out the bike wouldn’t start as the battery was flat, we managed to us jump leads from a car to start it but it seemed to build power before starting which I found strange. I rode straight to my dealers (16m) but felt it wanted to stall at low revs so kept it above 3k all the time, it was also running quite rough as if only firing on two cylinders. When I got to the shop I let it idle which it did OK so I stopped it and it re-started OK they checked it over and the battery read 12.7v & 14.3v charging but it wasn’t running all that smoothly so I have left it with them to check out as I have a 2k trip around Scotland in a couple of weeks so I don’t want it letting me down in the middle of nowhere!
What I don’t understand is that it was OK for 5 months after the first occasion back in November and how when I got to the pub it was flat but when I got to the shop it was fully charged, can’t be the battery as it has happed to both of them. I just hope they find something wrong and it not an intermittent problem that it hard to find.
Any thoughts out there?
