haki242
Hi, i have problem to sync my carbs.
The screw with withe paint is original all way in(closed) that mean max vacuum. The middle carb(screw) is also full in, closed. And the 3rd carb is 1 turn from full closed.
By turning the screew in(closing) the level of liqiud in tube is growing up(higher vacuum) And by turning the screew out, the liquid is dropping down(lower vacuum).
My problem is that the carb with white screew is full closed, middle is also full closed and 3rd is 1turn open.
In manual and everybody write that the screew with white paint should by closed full in and i can not adjust this screew.
So my question is, can i adjust the white screew? Why i can not turn the white screew? If i turn this screew i can sync the carbs perfect.
