lee1980
oooh its like Christmas! hehe I bet you try and squeeze shock together with your hands to lol hehe
had already "Turned-up" the settings after this week-endJust got back from having a static suspension setup
I'm pretty sure as a general rule with most bikes the sag should be 1/3 of the total travel. That said though there are some very good threads on FZ09.org with some sag settings in.Does anyone know what the ideal sag settings should be for the front and back and if so what are they?
The only real way to sort the suspension out if you can't get the stock equipment to feel right is to install aftermarket suspension. I would definitely suggest having it set up to your weight at proper place. I'm sure there will be somewhere within an hours ride from wherever you happen to be, it doesn't take long and usually doesn't cost too much. At least then if it still doesn't feel right then you know for sure that you'll be looking at aftermarket kit.Hi guy's, My MT 09F seems to woller around certain corners as if the front suspentions wants to soak up the road but then recoils to hard or something. If i keep the front loaded uo with the brake its not so bad but i just dont think its normal. Im 68/70 kg and i haven't been able to find a shop with information as to how to set it up for my weight. "The place i bought the bike tried to convince me you couldnt even change the dampening on the rear shock" hense i wont deal with them anymore. Has anyone got advice on how i should have mine set up for my weight? Any helps good help cheers!!
Yeah that's it, there are plenty of places around that specialise in prepping track and race bikes. Stick a thread up in the forum here asking if anyone knows anywhere decent in your area. Or Google it.Yeah i guess i need to ring around some more, go directly to a suspensions joint rather then moto shops. Cheers mate.
Welcome to the forum and happy new year!Hi guy's, My MT 09F seems to woller around certain corners as if the front suspentions wants to soak up the road but then recoils to hard or something. If i keep the front loaded uo with the brake its not so bad but i just dont think its normal. Im 68/70 kg and i haven't been able to find a shop with information as to how to set it up for my weight. "The place i bought the bike tried to convince me you couldnt even change the dampening on the rear shock" hense i wont deal with them anymore. Has anyone got advice on how i should have mine set up for my weight? Any helps good help cheers!!
Great info mate your a Legend, ill give it a try! ThanksWelcome to the forum and happy new year!
As i'm the same weight as you (68-70kg/150-154lbs) i suggest you until you find time to visit a specialist, to set the front springs preload at 6 rings showing (soft) and set the right leg's rebound reduced enough to avoid "pogo-stick" phenomenon after braking. Standard springs weight is 75kg/cm almost ideal for our weight..
At rear as we talk about stock shock i suggest to put the preload at 4 (for solo riding) and rebound from full soft till midle according your riding style/preferences and road condition..
Enjoy your bike.
