lou
Hi Slats, can you please give me info on changing the air filter as my DNA one should be with me this week? many thank's Lou remember (life's to short to grow up
It's really easy. Seat off. Air scoops off. Unbolt the tank. Disconnect fuel pump line. Fuel breather and overflow pipes. Unscrew the air box. Replace stock filter with the DNA filter. Put back together in reverse order. It took me 20 mins to do mine with a 5 mins coffee/fag break in between lolHi Slats, can you please give me info on changing the air filter as my DNA one should be with me this week? many thank's Lou remember (life's to short to grow up
If ur talking about the two rubber breather and overflow pipes don't disconnect them. Leave themHardest bits getting those little hose clamp things back on.
Did u get it on the dyno the Dna ?So...... The DNA filter turned up in the workshop today. We quickly took the tank off and installed the DNA. First impressions are......
The snatch has been slightly reduced even thought I didn't really have an issue with a snatchy throttle since the PCV was fitted an we dyno'd it.
Were dynoing at 09:30 today bud. Will post the results laterDid u get it on the dyno the Dna ?
I had the DNA in for about a week before we wrote the custom map for it and tbh it was slightly less snatchy but I didnt really have a problem with the throttle hence not buying a G2. Now it's been dyno'd the bike is exactly how it shud be. U can power on thru corners with no problems and the power is stupidly massive.Even more torque - bejesus
We still don't know the effects of just dropping a DNA filter in a std bike yet!
Thats the whole point, the orginal map values are crap, lean bottom end making it snatchy. The end goal here is to add fuel to the bottom end (as a lean mixture means snatchy throttle), and maybe by some chance fitting an aftermarket filter has made the bike do that for whatever reason.Don't ECU's compensate for either an inlet or exhaust change, but not both. This being the case, the ECU should add more fuel to compensate for the higher air flow through the DNA filter in order to maintain its original fuel map values. The overall result would be a higher fuel flow for any given TPS value. So either a little more power at the same throttle opening (at the cost of economy) or the same power on a smaller throttle setting with slightly less fuel being used. Just my thoughts.
I just ordered a DNA filter too. Mine was getting dirty a bit an notice a little lost in HP. Or maybe I just got use to it. LOLThats the whole point, the orginal map values are crap, lean bottom end making it snatchy. The end goal here is to add fuel to the bottom end (as a lean mixture means snatchy throttle), and maybe by some chance fitting an aftermarket filter has made the bike do that for whatever reason.
I've just fitted an ejk fuel controller to mine which is doing a great job of adding fuel where needed to compensate for Yamahas lean ass emissions map. With my standard throttle on (not G2) I pretty much have zero snatch, need to do some more riding and tweaking before I get in to a whole review but so far I'm really liking it, it seems very smooth.
Be interested in seeing what you come up with [emoji3]I just ordered a DNA filter too. Mine was getting dirty a bit an notice a little lost in HP. Or maybe I just got use to it. LOL
